- Southern Maryland
historically the plug is softer metal than the pan so that the plug will strip first
My HS shop teacher said when auto trannies first became mainstream, they had drain plugs. What happened during routine oil change, was the mechanic would pull the tranny plug thinkning it was the engine oil. The cars would leave with 10 qts of engine oil and no tranny oil, so Detroit stopped putting drainplugs in auto tranny pans.
I'm not sure how much truth there is, or where he heard that. [/hijack]
Firestone just did that to my father's Subaru. Drained the A/T fluid & changed the A/T filter! Put 4 quarts of additional oil into the crankcase!
They did not know why they could not drive it out of their shop!
Yes it is on the AW4. To service the trans, remove the plug and drain it. Install new washer on drain plug and reinstall. Add about 3 and 3/4 quarts of fresh Dexron/Mercon fluid. Double check the level per instructions on the dipstick.
brass, copper, or a hollow steel crush washer should be fine. A fiber or teflon washer could work as well but I'm not sure about longevity.
I would be tempted to brakleen the drain bore and plug clean and daub a little RTV on it.
I caught this on a Benz SUV that came into the quicklube I used to work at, it was one of those ones with the stupid plastic oil filter holder that screws in instead of a metal cased oil filter, one of the few things I recall about it. The guy in the pit drained the front diff instead of the oil, it looked a bit thick and not as dark as we expected, noticed it when we tested the oil pressure and checked the level (it was store policy to show the customer the dipstick after checking the level, to show that it was filled properly and clean oil.) To the pit guy's credit, it took the two of us about 3 minutes to find the damn pan drain plug with all the stupid skid plates and dirt shields MB installs these days. The front diff on the other hand was right about where you'd expect the oil pan to be, and the plug looked about right. They got a free diff fluid change service out of us, but at least we didn't screw up their car and have to spend a few grand putting new gears and bearings in it.
I like that drain plug. I changeout 2.5 qts of ATF when I do an engine oil change. So on average, my ATF is pretty clean.
