whitneyj
- Mayville, WI
so I'm in the middle of building a new crossmember for my tcase and my radius arm mounts, I'm also going to be building a full belly pan while I'm at it. I want to keep my tcase crossmember mount separate from the radius arm mounts and I want to keep it as flush to the frame as possible. Can I run a piece of flat 3/16 plate from rail to rail to hold the tcase mount? I understand it's under an incredible amount of torque, so I'd want to fold the metal up between the rails and mount it to the inside and bottom of the rails. My radius arms are 48 1/2" long so even with the axle pushed as far forward as I feel safe with the steering (about 3-4"), my mounts are still going to be behind the tcase. I know that's too long, but it's what I have to work with for now, when I have access to more equipment I'll shorten the arms to 36-38"ish. Can someone help me with the tcase mount? Will my idea be sufficient?
