outlander
- Columbus,Ohio
I'm not worried about it....the vents are so long that it would take alot to draw fluid out of them.
outlander said:nah the rv sewer hose has steel spiraling through it...it would take alot of pooh...or ummm vacuum for it to collapse
Are you smoking crack? No really, are you?BlueCuda said:I bet its very little. If it pulled very hard the stock airbox to throttle body hose would collapse flat.
GSequoia said:Are you smoking crack? No really, are you?
Revved up it's a shitload of vacuum and will create negative pressure in those lines!
Outlander, do yourself a favor and change thigns up. Run those vents high and forget about them (You can run them up the D pillar discretely if you want).
PS - The OEM hose is stout, ever try squeezing it?
Wil Badger said:uhm if air is flowing into the your motor with zero vacuum then how is the air getting to you cylinders?You motor is an air pump which means its creating a suction ie vacuum.
BlueCuda said:Any guesses on how much vacuum in inches is in your intake manifold when you are wide open? ZERO go put a guage on there and try it out, so same goes for the intake tube.
Wil Badger said:Before you go and get all shit mouthed, who said I was talking you ?
So now that I have proven I can read why not take your own advice.
flht1997 said:ok, an engine does not "suck" in air. when the piston goes down it will create an area of lower than atmospheric pressure and the 14.7 or so pounds of pressure we have surrounding us will then rush into the engine. in other words it does not get sucked in but rather pushed in.
nice work, nothing to worry about.
Tommy4949 said:I meant to ask before, how did you move the ECU into the engine compartment? Splicing wires, did you use another wiring harness to make it longer or what?
Its in the cab from the factory....
(quote:myself)
"I need to get two 12v marine sump pumps to mount inside under the front seats to pump h2o out of the cab.They'll be wired into a toggle switch and when the water level starts to rise in the floorboards I'll flick the switch so my interior/computer/feet stay dry"
