outlander
- Columbus,Ohio
Got bored and snapped a few pics of my extended vents and snorkle:
Here you can see the front of the airbox that I sealed up with silicone with the factory vacuum operated heat riser door:
the fitting that goes into the cowl.It sits up off the the floor of the cowl and is angled down:
hose attatched:
vent lines extended and ran into airbox using air compressor quick connect fittings threaded into the airbox lid:
distributor vent that runs over to the airbox:
a pic of some of the vacuum line y connectors I used to run the lines to the airbox.To the left you can see my spare starter mounted to the firewall:
Future plans are to find a top hat intake like found on humvee's and mount it ontop of the cowl.
welp thats it...let me know if you have any questions.....
hose attatched:
