bluejeepkid
- Bullhead City
Truss seems alright, but I don't see why the notch is needed? It would be a lot stronger if it we're 1 straight piece.
i like to go fast, and crawl. its a hybrid of both worlds
nice fab work. looks good. all that matters is that it works for you and what you need it for.
Wasn't knocking your build man, it's good work. I was just asking why you asked for opinions just to blow them off. Good job again and I'm glad you like it.i chose to build it on bottom so i could stretch the truss all the way from C to C.
for what i do with my xj, the loss of clearance isnt too much of an issue. i live in a sandy area, its mostly a beach goer with occasionally rocks.
Makes sense I guess, but you limit yourself in the longrun...imo
and besides, if you pick your lines good enough, you dont have to worry. who picks lines that force you to straddle large boulders anyways?
I guess if you arent use to running in the rocks you wouldn't understand. With your assumption you are saying there is no reason for skidplates as long as you pick the right lines?
Im about to start on a truss for the 30. Its a disconnect housing with a one peice passenger axle shaft conversion. I was wondering if anyone has bought a premade truss and modded it to fit the disconnect housing? Also, i know the center section and the passenger UCA mount are cast steel. Do i still have to preheat the area before welding? And i am also going to gusset the C's, should i remove the balljoints or will they be ok?
on a side note...
feel free to post pics, I havent started yet and am still looking for ideas
A modified bought truss would go on top...Correct? Unless you know of a company that sells an underneath truss I am not aware of.
as far as i know you are correct. he also stated that he decided to truss the bottom instead.i personaly don't care which way he or anybody else goes about fabing their own stuff.he is the one driving it and knows how and where he drives it. although everyone has an opinion,that dosen't mean it is right or wrong. i just don't like to see people being pick at or on for their ideas or ways of doing things. as i will always say "To Each Their Own"
You're right I'm an idiot I don't understand what an opinion is, thanks for clearing it up for me. Have a good day.
That is where I was trying to go with it...and you just wanted an excuse to use lmgtfy.com lol.its not how i would have built it, not at all. but the fab work looks far better than i could do, so kudos to the OP there.
