faraiwe
- NE Florida
I call this shot "Hopeful Synergy".
It contains everything harvested (from a single '99 XJ donor vehicle); trans with transfer case, assorted screws and fastener plus wires, goofy auxiliary shifter linkage, trans cross-member, front axle with diff plus assorted linkages, front driving shaft, new trans fluid filter and gasket, bottles of varied fluids (diff oil, brake cleaner, lithium grease, sealers, WD40, ATF and all-important Gojo). I plan to re-use a lot of screws and other small minutia from my own currently installed parts.
I am also getting an after-market rear diff cover, because that shameless rubber plug annoys the living beejeezus outta me. :nosmile:
But for that suitable rear shaft, here I go. I am hitting the yards again. eBay seems to have a few options, but overpriced, and no one seems to be able to verify if the drive shaft's spline is compatible with the rear differential. :tear:
INCIDENTALLY... before I even advance. I THINK I have a Dana35. There's some spray-on material over the markings (it resisted power spraying at 1400psi), making reading them a feat of imagination. An XJ differential identification doc seems to confirm this, but it's all I got to go on. Two marks SEEM to say "TB4 HS3760" (??) and "<Chrysler Star>12767 52809336" (???), but can't find anything else. The diff has the ten-bolt cover and left side bulge, with the mentioned rubber plug. :helpme:?
