seanof30306@yahoo.
- Tulsa, Ok
Steering wheel shimmy is not the same as death wobble.
Steering wheel shimmy that starts when you a hit a bump and doesn't end until you slow down isn't exactly death wobble either.
I have never read of steering stabilizers fixing death wobble.
My 01 XJ which I've had for over 300,000 miles has only given me vibration and shimmy problems three times that I can remember:
1. Tires out of balance around '07-08.
2. Brake rotors somehow defective around '11. Problem was only noticed downhill at speeds over 40.
3. Tires out of balance or damaged, worn steering tie rod end around in '15. Hit a bump and the steering wheel starts shaking until you slow to 40 MPH. Found defective TRE at steering box/drag link. Shaking was reduced but still present. Then I put my old tires back on and the problem went away. Two of the "new" tires I took off would not stand up straight on their own.
While I was in there for #3, I found the steering stabilizer was worn. I replaced it only to solve problems with the steering wheel shaking back and forth a few times on damaged road surfaces that had been going on for a few years.
http://www.thecarconnection.com/new...re-chrysler-posts-advice-on-jeep-death-wobble
http://www.jeepforum.com/forum/f9/s...e-bulletin-19-002-12-steering-shimmy-1402104/
