Seems rust a eaten up the rear of the system. I am going to put on a cat back I was going to use a Thrush or a Dynomax Muffler. Is it worth going to a 2 1/2 from the 2 1/4 stock pipe or will the turbo muffler make a big enough differance on its own.
get the rusty's cat back system. If you want real loud, get the 40 with it. If you want a nice tone but not too loud, get the 50. My friend has it, and I wish I had gotten that instead of my Dynomax Super Turbo Cat Back System. Besides, it seems as though Rusty's uses a thicker gauge steel than dynomax on the tailpipe.
Maybe I worded it wrong I am going to have the tail pipe made up I just do not know if there is a big differance in the 2 1/2 or 2 1/4 in. pipe aside from a 1/4 in. Are there any benifits to going into a larger pipe.
not really... Yeah, it's free-er flowing, but wont make much of a difference because of the 2.25" pipe between the cat and the muffler.
If you wanted to make a difference, get a high flow cat w/ 2.5" inlet/outlet and then a 2.5" pipe to go from there to a 2.5" inlet/outlet flowmaster 50 or 40 and a 2.5" out the back.
Correct that if I'm wrong, but I'm pretty sure the inlet to the Catalytic Converter is 2.5". (I think it's 2.5" from the header Y-pipe to the Cat).
if you want a good sound, IMO, the dynomax super turbos are a waste of money.....the ultra flo dynomax sounds pretty good, 40 series is ok,and the top of the line I believe to be the banks catback system.....
I did that with a magnaflow 2.5" cat, flowtech terminator muffler, and 2.5" pipe throughout. With the new cat I noticed a difference, but my old one was toast.
A 2.5" tailpipe will, at the very least, increase resonance. Something about the exhaust gasses cooling and the larger diameter outlet.
im gut n the cat and running 2.5inch for a foot or so then a 40flowmaster and then 2foot or so to a side pipe running out right before the rear wheel. Havent seen n e one do this.
