- Bakersfield, CA
xjnation said:on a llifted rig with no swaypars I always run neutral shocks so Im not fighting the shocks trying to push the rig over on every corner
Brian, shock technology has come a long way. I know we all have our personal preferences, but the idea of a shock being able to dampen wheel movement and provide a good ride at the same time is why shocks use biased valving. They're softer for compression so the ride isn't unnecessarily harsh, and stiffer for extension to control the wheel movement. A stiffer extension setting adds considerably to stability, and stiffens the ride, even with the compression setting staying the same.
Case in point is the Rancho RS 9000 shocks. As they are adjusted up to stiffer settings, the stability goes up quite a bit, yet only the extension valving is changed, the compression valving stays the same. With my old spring rates, running my rear 9000's set on 3 it needed the sway bar, but on 5 it was fine without it. If you're comfortable with 50/50 biased shocks, well, we all have our preferences, but that is very old shock technology.
