SurplusFan98
- LA
Hi all,
Just a little context: I'm restoring a 98 2wd XJ with 300k miles that caught fire and burned (because I'm a masochist I guess), and I don't yet know what all is wrong with it.
Currently I'm replacing an AW4 transmission pan, so I pulled one from the yard. While I was at it, I noticed that the solenoids in the doner tranny looked really good, so while I was at it I pulled those too. Now that I have the pan off of my tranny, I can see that my solenoids look.... old and kinda burnt, I guess. So, I went about trying to test the solenoids I pulled. All 3 are showing about 12.8 ohms, which appears to be correct based on what I've read. I then hooked them to the battery to confirm they "click" indicating that they're operating. On the 2 identical solenoids, the ones toward the front, I get a defined click, so I feel confident that these will work...
On the third solenoid from the yard, the one most rearward in the transmission and what I've gathered is actually referred to as the "#2" solenoid, I get no click. This concerned me, so I pulled my #2 and tested it. With it, I get like 38 ohms, and also no click. Pretty sure that means mine is toast, but the fact that I got no click in either case made me question myself. Am I supposed to get a click or not? I would think so, as it seems like opening and closing is the thing's one job. But, I've been wrong before, so I'm asking. I don't want to have to drop this pan again...
If it helps, with the #2 solenoid removed, I get 2 codes: P0700 and P0743
If you guys tell me I need another #2, ok, sell me one for cheap, because O'Reilly wants like $200.
Thanks all!
Thanks all!
