joe_peters
- Grants Pass, OryGun
Dang it--you are one pain in the toolbox!
Thought a little levity might help.
Would you believe I have just read this thread all over again?
Spark--present, rotor is turning when the engine cranks, right? You are getting spark distributed to each of the plugs in turn?
Fuel--quantity and quality. Disconnect the fuel line back at the tank and have someone turn the key ON, pump fuel into a clear glass container, about a quart, let it set for awhile and see if any water shows up in the bottom of the jar.
Air--You have got to be getting air, I know you pulled the intake off and sprayed ether into it.
Compression--you tested and showed one bad hole. Try this, take off the intake and have a friend hold the throttle open and crank the engine over with your palm over the throttle body. Disconnect the main coil wire from the distributor--the chance of a spit-back is probably ZERO, but I'm anal and don't want you hurt. You should feel the engine sucking your flesh into the throttle body--sounds worse than it feels. If you think it feels too weak, try it on a known running engine--again, disable the coil wire.
Fuel, air, compression, spark, each of them present at the right time, in the right quantity, and Houston we have ignition.
Take a break. Walk through each of the above, AGAIN, slowly and think it through. You are our eyes, ears, hands, and sense of smell.
Post back what you find.
