Fuel pump will not prime
Well there's only 3 things on the list so until you've checked them ALL...............
If you have 30 and 87 jumpered and you do not have +12 volts (to a known good ground), then the wire has failed!!!!!!!!!!!!!
30 is fed directly from a fuse in the PDC
Main fuse block (PDC) not a PCM!
