lawsoncl
- North Idaho
That was a cut&paste from the FSM. It's referring to the plug for the NSS. I doubt it's the NSS, as it make no connections when it's in (D).
If the solenoids are measuring good, they probably are fine. They are pretty pricey at $160 each, unless you can get them used. With the ignition on, are you getting voltage to just the first (A) solenoid? If you are, then the TCU is working and the tranny should be giving you 1st gear.
