- Colorado
y’all convinced me... lubelocker it is
Before there were a lot of beefy diff cover options, I built several of these using the stock D30 cover and 5/8" steel rod.
http://i173.photobucket.com/albums/w52/XJEEPER1/XJ Build III/100_0954.jpg
I've run Ruffstuff diff covers on both end for the past 12 yrs. Drain holes leaked in both, so I welded them up and run Lubelocker gaskets, for simple fluid swaps.
Agreed,The difference is the ring gear rotation, in a rear axle the oil has to travel all the way around bottom to top of the ring gear before it gets to the pinion. In a front axle the oil has to go from the bottom of the ring and directly to the pinion.
X1000 on the Lube-Lockers. :thumbup: :thumbup: :thumbup:
do you DD your rig?
If not I would go with 1. solid$$(personally running this with zj steering) but had I know differently when I bought it, Ide probably look for a better DD cover, .
Pretty happy with the purchase after measurements... dunno if there is better out there, but for the price, included bolts (rtv will be added to the stash due to lubelocker), and this prifile- its exactly what I need. Drain plugs are cool, but the diff is so small draining it is literally the easiest part of the whole front axle fiasco Ive done so a luxury Im not sad about lacking.
Millions of jeeps have been running afternarket diff covers for eons, cool research but im not concerned in the slightest. Rear is a 9" so all she has is a pinion guard and a truss gtg
Somwhat is it that you learned?
I have solid covers for front and rear, bought them because the price was right — with lube lockers
I have not installed them— was waiting till I built the axles
Yes, daily driver — curious as to why I shouldn't use them
