Sure why not....the axle will swivel on the one axis(being the uca's)adjusting your caster.You could even use the uca's alone to accomplish the same thing(then your lca's would be the pivoting axis)...
However you want to first center the axle in the wheel well so that your wheelbase is correct using both upper and lower adjustments and then use one or the other to fine tune caster/ds angle...
keep in mind that if this is going to be streeted the front ds angle is first and foremost,caster is socondary for obvious reasons...
