Dodge used to recommend rings if the oil consumption was more than a quart every 500 miles. Seeing as how you seem to be using most, if not all, of the oil through one or two cylinders, it does seem like a lot.
Get a good flashlight and look in the spark plug holes, a video scope is even better if you have access to one. You may have a notched piston or worse a broken ring and some serious scratches on the piston walls.
To bad I don't live anywhere near you, I have two motors you can have.
The one plug looks like a head gasket, the other like oil. Maybe the oil fouled one is a combination of coolant and oil.
Fire up the motor cold and hold a white paper towel near the exhaust until the motor heats up and see what it spits out the exhaust.
Make sure your oil pressure scavenger tube is clear, the tube and both the outlet and the inlet.
People forget about molybdenum, the good stuff is expensive, but it will sure slow down oil ring bypass. Hard to find the good stuff anymore, Liquid Moly used to be good but the actual Moly ingredient in their stuff is negligible anymore.
