I'm the one ChiXJeff mentioned. (I'm a new member - just joined, although I have been reading the forums off and on for quite a while.) I put the cluster from a late '80s XJ into my old '85 - the only ones I could find at the boneyard were from 6 cylinder XJs. Poking around the tach, I discovered that they are just using a frequency to voltage converter - the tach guage itself is nothing more than a voltmeter. I hooked the new tach up to 12VDC power, and gave it an input with a function generator. I checked the output of the function generator with a frequency counter. I then adjusted the trimpot on the converter to get the correct reading. (IIRC, the tach gets its signal from the ignition module, and that is just a pulse train that comes from the pickup in the distributor. In the 4 cylinder, 1 revolution of the distributor equals 4 pulses, and that equals 2 revolutions of the crankshaft, so 2 pulses equals 1 RPM. In the 6 cylinder, 1 revolution of the distributor equals 6 pulses, which equals 2 revolutions of the crankshaft, so 3 pulses equals 1 RPM. I set the function genearator on 2kHz and adjusted the trimpot so that the tach read 1000 RPM - that seemed to do the trick.) It's been a few years since I did this, so I am a bit fuzzy on the details at the moment. I do have another 6 cylinder tach that is unmodified, and I am working on a writeup (with pictures even!) about how to do this. As far as I know, this will work on the clusters with the cable driven speedometer - I am not sure about the full electronic clusters, since I haven't played with one of those yet! All this leads to a question that I have - once I get this written up, how do I go about posting it in the Tech Articles area?
