Scuuba Steve
- Ri
Hey all, first post on a Jeep forum but that said, I understand the process.
I have a 2000 Cherokee sport on 31's with 138k on the clock that I bought with a 3" lift. Coil spacers and blocks, that's it. Chrysler 8.25 rear end, low pinion D30 up front, 3.55's
I've had plans for a 4.5" lift since buying it. My questions are:
Will I need a SYE? ---Found mixed answers.
What angle/degree axle shims will I need for the rear?
Will I need a drop pitman arm? ---Found mixed answers about that depending on trackbar?
So far my to be lift consists of:
Rustys 4.5" springs
Zj rear lower arms
Sway bar disconnects
JKS adjustable track bar
Yj brake lines front and rear
Things I have yet to get that ik i'll need:
T-Case drop
Axle shims
Considering a Dakota bastard pack with 1" Rough Country drop shackles for rear ----------- Clueless on year, 2wd, 4wd, trim etc for dakota leafs
PLEASE tell me if I'm missing anything I intend to make this an all at once project.
I just want to make sure I have everything I need before I tear my daily driver down.
Excuse the ignorance with some of the linkages, this is my first vehicle with TWO solid axles
Plans for a mechanical Aussie Rear locker, anyone know any good shops in RI/CT area??
Rustys 4.5" springs
Zj rear lower arms
T-Case drop
Axle shims
