Talyn
- Radford, Communistwealth of Virginia
I think he meant file the holes in the CPS it self
Oh!! OK that makes more sense. I was getting worried for a minute. Thanks
So, if you pull the two bolts out and try pushing it down closer???????????? If it's not real close, you could file the holes open bigger.
Did you see somewhere that there should be no resistance? The only thing I could find in the FSM is that it should go from 5 volts to 0 once it passes the last slot. I figured that you would have to put your voltmeter into the ground side (probably the black, and crank the motor watching for the voltage swing. A test light would probably work better. And you would probably have to pull the coil or something so that it would just crank slow and not start.
I should have never thrown out the factory installed CKP that went bad. I would have something to compare this one to. The old one had resistance, which, according to this test it shouldn't have any resistance i.e. open. The way I'm figuring if I'm getting any resistance it is a bad sensor. I'll try holding one lead in each hand and see what I get! I plan on doing the test 2 tommorrow and see what happens. ThanksOK, now you're teaching me. But a couple of observations. But I'm not an electronics expert.
1.) On that link, he says to set the ohmeter on the 1k-10k scale and that you should have infinite resistance. You are measuring 33.4M. Is that not 33400k? That may be relatively close to infinity. What do you get if you hold one ohmeter lead in one hand and the other one in the other hand? You will get a reading, but I don't think the conductivity is very high.
2.) You probably noticed the test for the 0 to 5 V fluctuating voltage that I suggested form the manual.
aperwork
You are looking for HIGH resistance (close to infinity). Low resistance is the opposite which would be high conductivity. High ohms number = high resistance. What keeps it clear, though is when you say "open", which is very high resistance. Low resistance is what you have when you touch the two ohmeter leads together (ie.closed circuit). I think we mean the same thing though.
I think so (but I don't know). We either need someone with greater knowledge than ours, or at least able to check a known good. Sorry, I don't want to crawl under mine in the snow to test. Do they have these in stock at your auto parts place where you could test a couple of them?
I come back to the diagnostic point I raised several times. We don't factually know whether you have spark or not when it doesn't run. I suggested popping the coil rail off, when it doesn't run, and putting a spark plug in, then holding the plug base up to the engine to see if you really don't have any spark when somebody cranks it.
I know that the assumption at this point is no spark, but, WHAT IF???????????
Put it on a stove burner and check the resistance???????????? And I do think you won't get spark, but just think you should test. You obviously know what the word assume breaks down to. ass/u/me!
I will do this test as well. Lets, just for a moment, assume I don't get spark when I test the rail; would this then point to the CKP? Is there a test for thermal failure of the CKP?
