VOTE NOW for September 2009 Rig of the Month!
VOTE NOW for September NAXJA Rig of the Month
  • ktm racer 419
    Votes: 55 31.6%
  • lesslimited
    Votes: 32 18.4%
  • SC Rednek
    Votes: 13 7.5%
  • -96JeepSpeed-
    Votes: 15 8.6%
  • Begster
    Votes: 59 33.9%
  • Total voters
    174
  • Poll closed .
Bryan C.
Antioch, CA
Official September Rig of the Month submission thread
Same rules as before, first 5 red letter names to be submitted with 2 good quality pics and a spec sheet will be voted on. All winners will be featured on the front page of NAXJA and are eligible for the Rig of the Year contest in December.
Good luck!
Re: Official September Rig of the Month submission thread
Submission #1
96 cherokee classic
4.0
aw4
np231
36" iroks
15x8 allied 32 bolt black beadlock wheels
trussed Dana44 front
out of a 1987 jeep j-10
chevy half ton disc brakes
yukon 5.38 gears
30 spline lock right with titanium cross shaft
30 spline alloy/chromo shafts with yukon super joints
warn premium locking hubs
rockkrusher diff cover
high clearance control arm brackets
custom over the knuckle, inverted "T", one ton steering using chevy tie rod ends
u bolt style pinion yoke
Dana60-2 rear
out of a 1973ish international milk truck
caddilac eldorado disc brakes
yukon 5.38 gears
strange engineering 35 spline spool
35 spline moser alloy shafts
whole milk friction modifier (increases locking action of the spool)
SOLID diff cover
ruffstuff antiwrap leaf spring perches
high clearance shock mounts
2" lift coils
custom longarms using a mish mosh of 7/8" heims, currie jhonny joints and ol' fashioned bushings (radius arm)
tnt customs heavy duty trackbar w/ brace and 1/2" bolt mod
10" travel edelbrock ias remote resi's in front
8" edelbrock ias outboarded shocks in back
fancy front brake hoses off of a late 70's dodge van
dodge dakota rear brakeline
bastard leaf pack using all re leaves (from a 3.5" and 4.5" pack
1.5" rocky road outfitters lift shackles
dpg adjustable bumpstop plates
progressive poly bumpstops in back
progressive prothane bumpstops in front
tnt customs unibody stiffeners
custom flat belly skid/crossmember
2x6" rectangle tube front bumper/crossmember
custom 2x6" box tube rocker panels
high clearance fuel tank tuck w/ skid
heavy duty sye with stock front cv shaft in the rear
t-case is clocked for flat belly
10lb co2 tank
grand cherokee 60/40 split rear bench seat
sweet jvc hd radio
doorless mod
Submission #2
Probably not too impressive compared to ktm racer's but a decent daily driver/capable trail rig. Supposedly it's my wife's, but my name is on the title :D
'99 Limited, 4.0, AW4, 242
Leather seats, power everything, premium sound, factory skids
Front suspension - 3" RC coils, ACOS, RE upper control arms,RC drop brackets, JKS lowers, JKS discos, TNT track bar and bracket, ZJ steering assembly, poly sway bar bushings
Rear suspension - assorted leafs from spare parts pile, JKS shackles
245/75-16 MTRs on Soft-8s
Loose Nuts bumper with Mile Marker 8k winch
D30, 4.56, Detroit, re-inforced control arm mounts
8.25, 4.56, Detroit, alloy shafts
RE hack-n-tap SYE and DPG driveshaft
AFE intake, Dynomax cat-back
Driveway shot
Golden Crack
Submission #3
'99 Cherokee Sport
4.0
ax15
np231 w/ SYE
4.5" lift springs
3/4" front spacers
1" lift T&T boomerang shackles
33x12.50x15 MTRs
HD track bar and brace
Steering box brace
Tom Woods rear driveshaft
JCR Offroad Bumpers and Sliders
Winch
Lots of lights
CB radio
Homemade:
Tube doors
Light bar
Tail light boxes
Dual battery setup w/ disconnects
And it's not just a daily driver, it's my only vehicle
Submission #4
My daily driver
1996 Sport with 175K.
RE 5.5 Short arm with BDs
Locked 30/44
Trussed 30
BTF Diff cover
5150s in the front
14" fox shocks in the rear with bed cage
Ballistic fab steering
Over axle trac bar with JKS parts
C-rock plate
Custom front bumper
DPG belly pan
231 with crown sye
RE driveshaft
5-Speed swap
Novak T-case linkage
Abunch of random body parts off Junk yard jeeps
33 BFGs
Rocker replacement sliders
Guted interior
RE TB bracket and brace
Skids all around
Frame stiffeners
2.5" exhaust Header back
K&N intake
Submission #5
'99 Jeep Cherokee Sport
4.0/AW4/NP242
RE 6.5ish lift
RE drop brackets w/ adjustable RE arms
33x13.5 Toyo Open Country M/T's
15x10 Cragar soft 8's
RE H&T with custom shafts front and rear
ARB bullbar that is now cut up and modified
Airflow snorkel with Donaldson air canister
FlowKooler high flow water pump/all aluminum radiator
Warn M8000 (not pictured)
Rocker guard on driver side only
Front Narrowed HP44
TNT truss
4.56 Yukon gears
OX locker
Custom Alloy USA inners/ Moser outers
Warn Premium hubs
FSJ flat tops/ Parts Mike high steer arms
1.5" DOM 1/4" wall steering with 1 ton TRE's
Custom trackbar w/ RE superflex joints at both ends
Bilstein 5150's
Rear XJ 44
Ruffstuff truss and double shear shock mounts
4.56 and OX locker
Superior shafts
I'm sure I'm forgetting things
[size=-3](Yes I know the axles are overbuilt for the size tire, but that will be changed at some point in the near future)[/size]
Thanks for the submissions. This thread will be locked until I can get the poll set up.
VOTE NOW
Time to vote for September Rig of the Month.
Poll is open for 7 days. Good luck to everyone.
Mark, you've got my vote! Good luck dude.
Nice pile of crap but your whole milk thing..........:twak:
Submission #5
4.0/AW4/NP242
RE 6.5ish lift
Front Narrowed HP44
TNT truss
4.56 Yukon gears
OX locker
Warn Premium hubs
Bilstein 5150's
Rear XJ 44
4.56 and OX locker
Superior shafts
[SIZE=-3](Yes I know the axles are overbuilt for the size tire, but that will be changed at some point in the near future)[/SIZE]
Very nice!! Just how I like'em BUT I had to vote for lesslimited.........
Thanks Adam.
Thank you. And understandable, that's a very nice clean rig. Mine used to be that clean when I first got it.
At least you know that.:D
-Alex
Its piece of mind as well, I know that I won't be breaking when I'm out on the trails. I figured I wouldn't skimp with anything when I was building the front axle, because I didn't want to have to do anything over.
Agree and you got my vote. I'm a fan of over built clean rigs, they won't break down as often when the zombies attack. :gee:
All the other rigs look great but I friggin love the look of John's wife's rig I had to vote for it. I'm partial to moss green XJs on 31's anyways! :D
