replacement OME bushings ?
camarors8992
I got a set of front OME shocks, but the lower bar pin had been removed and the bushing is distorted, i've checked JCR, Rough Country, RE, OLD MAN EMU's website, and Rusty's with no luck on a replacement bushing. I'd prefer if the replacement didn't have a bar pin.
The lower mount of the rear OME shocks takes a bushing without a bar pin. Those bushings fit the front shocks as well, so buy replacement OME bushings for the rear shocks and install them on your front ones. I still have mine in a packet somewhere - if you don't come right I'll look up the OME part no. for you...
Call Dirk at DPG Offroad. I'm sure that he can point you in the right direction since it involves OME stuff.
