YeaItsSlo
- New Haven,CT
Is it possible to use the axle shafts out of a ZJ aluminum housing on a xj 44 housing?
Appalachianxj said:The ZJ D44HD have c-clips and I think a ABS mode ring.
xjjeeper19 said:is the flange square?
xjjeeper19 said:it is a ZJ axle, but i got one more question....where the splines are at the end of the axles...does one axle have splines cut alot further down the axle than the other?
xjjeeper19 said:I'm not sure, as long as the splines are the same and so is the lenght i would say go for it. just check the bearings and the races to make sure they are the same too.
xjjeeper19 said:the backing plate should be the same it is bearing or the splines that are different, but i could be wrong.
Bryan C. said:Those don't look like ZJ shafts to me. The guy who posted about a ZJ rearend having c-clips is correct. Those shafts in the pic are either TJ, or XJ shafts. You need to count the splines to know if they are D44 or D35. You got any pics of the housing?
YeaItsSlo said:They are 30 spline, i counted them.. and they dont seem to have C clips.. The housing i have is complete with axles already, and is a xj d44.. The guy i bought the d44 gave me these and wasnt exactly to sure what they came from..
