Love2Ride450
- Roseburg, Oregon
I did a ghetto fab plumb job on her for now, and it works nicely. I don't have any more pics at the moment, but I will post them. I have only the bare necessities at the moment. I am also using the original pressure hose from the compressor. I went by the local NAPA (my work place) and picked up two 1/4 pipe street tee's, a reducer coupling from 1/4 to 1/8 for the pressure switch, two automotive type quick couplers, a 25 foot coil hose, a 3/8 barb fitting to 1/4 male pipe, and some teflon tape. I already had a pop off valve.
I do not have a water trap at the moment, but I just was wanting to test this thing anyway. The pop off valve is at the bottom of this mess, so I can use it to drain any water from the system each use. The pressure switch is at the top, and is just behind the compressor so the original clutch wire is long enough.
The result..... I let my 32x11.50 15 down to 9psi. I fired up the heep, turned on the compressor and started filling my tire. I stopped after one minute elapsed. 30psi !!!!
The only drawback right now is I have to open my hood to get to the quick coupler. As stated, this is only temporary, I plan on building some rocker rails from 2x4 rect. tube, and will make them my air tanks. Each side will have a quick coupler on it, so I can simply unhook my hose and take it to the other side. I did the math, and it appears that two rock rails, at 60" long will be just over 4 gallons of air space.
