XJ longhouse
- Grapeview, Washington
sounds to me like the hub unit bearing might be bad. jack the axle up on the side you think is wobling so you have only one tire off the ground, then grab the tire top and bottom and try and wiggle it , if it moves most likely hub unit bearing bad, try it left and right as well , if it moves thisway but not up and down it eigther ball joints or TRE's have another person watch for you if it moves left and right to be sure, they'll be able to see it move
Rig looks good
Rig looks good
