I'm going to try and tackle this project on my 94 next weekend, i already have the interior gutted, is there anything i should move or remove from the undercarriage? I only have 3 or 4 holes that are about 4" across. I'm confused about what you guys were talking about in regards to welding the entire pans and what not, since i'm only going to need a few peices that are so small, is it ok to put a bead of weld all the way around the patch i make? Also is it ok to overlap the metal and then weld or does it need to be cut to the exact size of the hole? I also dont have access to a welder anymore, is the link to the spot welder at the beginning of this thread going to work for what i need to do? Thanks for any input, again i've never done anything like this before so any additional info will help. Thanks!
