Here you go guys, just finished this one for an XJ, a full blown cage at its finest. Maybe a little much for most people, but given a drawing from our customer, this is what we came up with. While we were not paid to do it on this particular jeep, we would recommend sleeving the unibody with channel or plate, then tying from the existing rollcage sandwich plate to the unibody. Its clean simple, and bombproof. The back seat will still function, if you omit the diagonal running from the forward center hoop to the rear center hoop. While hard to see in this particular picture, the cage ties to the frame with 28 1/2" bolts. It also reinforces the critical B-Pillar area, by tying into the existing shoulder harness bolt, with a preformed 1/4" bracket. Note: Rear Passenger leg room is tight, with the X behind the driver seats. Also, we are no long going with the flanged bolt together design, we use a cleaner, stronger sleeve design, with 3/8" pins. This cage comes apart in 3 pieces. THe only downfall, is the lower half of the X must be welded inside the cage, thus making the cage unremovable from the vehicle. Just a few fun facts about this cage. THere is 123 feet of tubing (roughly 250 lbs of weight spread over the vehicle) 70 welds (not including gussets), 62 Notches, and 2 Grab handles. The cage is 100% TIG welded. For a cage like this, its best to bring us the jeep, wait about a month, then come back and get it, and be prepared to get excited.
This picture was an in progress pic, we have up on our server. More pics available upon request, by email
[email protected]
