Tonybeirut
- Lebanon
At this point, no I am not sure I would trust the mechanic.
1) The 'new' axles would not move the carrier by putting pressure on the bearings...the axles have a certain degree of float to them normally, and they can move in & out up to 1/8". So if their was any pressure being generated, the axle would just move to get rid of it.
2) Yes, the c-clips will move with the axle....push the axle in till it hits the center pin, and that is how you remove the c-clip....pull it out sharply, and that's how you seat the c-clip.
3) There should be a gap between the center pin & the axle ends once the c-clips are seated (axles pulled all the way out until they seat)
4) The axle SHOULD touch the brake drum housing, as the drum mounts ON the axle. Now, the axle should NOT touch the backing plate, but if the axle is touching the backing plate, you HAVE NO axle bearings...they are gone. I am not sure what or where you are saying they are touching (axle & drum)
5) I'm not sure what is going on from your description and the pics, but you got something wrong, and I can't see just changing axles causing this.
The axle flange/studs is where/how the drum mounts to the axle
Not sure on the "worn after the c-clips" or the "slipping when cornering" statements
and if you grind the brake drum on the inside all the way around, you basically make the drum large enough that the brakes aren't touching it, so yes, any sound would go away.....
do your rear brakes even work now ???????
Worn after the c clips part i meant the part that touches the cross pin of the carrier.
Slipping when cornering mean sliding? (in and out movement from the diff housing) Sorry.
Rear brakes are working but not like before grinding the drum so I will change both also.
