Tonybeirut
- Lebanon
Good morning, this is my 1st post for a problem , i didn't find answers at any previous post for my problem so here i am asking here maybe i get help.
I have xj country 1994 with 4.56 USA standard gears and arb locks (on chrysler 8.25 / 27 spline). 250k on it.
I heard a metal friction sound from the right rear end when cornering to the right.
Found out that the edge of the axle at the brake side was touching the drum brake.
So the mechanic Removed the axles and both were worn at the top end side (after the c-clip / the part that touches the cross pin in the carrier)
The shop changed the axles and inserted them without removing the ring and pinion , he checked the backlash and settings all were ok.
I noticed that the axle top end was touching the cross pin (both axles end laying on it).
The cross pin is with a full notch (top to bottom).
I Drove the jeep for about 40 miles then a whining sound came from the gears on acceleration and deceleration.
Opened the diff next day and the ring was worn plus silver color of metal found in the newly changed oil. (oil was also with black color)
I will buy and ship new ring and pinion and install it but im afraid to have the same problem again.
The mechanic said that it was the pinion bearings that made the pinion move and caused the ring to wear, when the axles were worn they released the pressure on the faulty pinion bearings and when they were fixed the pressure returned to the faulty pinion bearing and made the pinion move to affect the ring.
Anybody had this issue before or any idea what caused the ring to wear so i can check it before installing new gears set?
Is it normal for the axles end (after the c-clip) to touch the cross pin on both sides when the jeep is parked (not driven)?
Thank you
Thank you
