Vanimal
- escondido, ca
not doable, it wont fit (i looked into it)
Just another Idea before I start welding.
Using WJ knuckles, Has anyyone went OTK with the tie rod but left the drag link UTK?
it looks like this would help with the track bar/drag link angles.
I have been researching like everybody else but I just want to do the cross over steering and beef up the track bar, tie rod and drag link. I just converted the rear to disc and the BB/MC to dual diaphram and with 33" it stops like a race car!! Can I do all of this and not do the big brakes up front? If so, do I still have to use the spacer and different upper/lower ball joints and such?
Has anyone written a final summary of these 16 pages, into a concise HOW TO and WHAT PARTS TO USE?
Where's the link?
This started out as a 2001 swap... then it spread out like an octopus...
- If you want stock WJ TREs (all four TREs):
- Napa 269-3155
- Napa 269-3158
- Napa 269-3157
- Napa 269-3156
- If you go 1 ton offset TREs for draglink:
- ES2027 for pitman arm
- I used an offset 1ton tre from parts mike for knuckle end but cant remember the PN
i reamed mine and it was easy, but you need to make sure the hole is square to the knuckle. you should really use a drill press capable of really low rpm with the knuckle clamped down good, or a mill.
i reamed out my knuckles just fine, not sure where you got that info.
