5-90
- Hammerspace
Daedalus454 said:While I certainly agree with you that the Vista UI takes some getting used to, I find that while it's different I don't necessarily like it better or worse than XP. When transitioning from Windows 3.1 to Windows 95 I had much the same response as many seem to be having to Vista. I thought it sucked, but ultimately I learned to use it and even prefer it over Win3.1/DOS. I overcame my dislike of the UI due to the underlying technological enhancements that were beneficial and eventually required for many applications. While many insist that Vista is nothing more than a visual UI retool of XP, nothing could be further from the truth. Vast amounts of underlying source code were completely rewritten in the interest of speed and compatibility. I can tell a huge difference in the stability of my system with XP vs Vista - Vista wins hands down.
As far as hardware compatibility goes, I personally haven't had much trouble. In March when I first switched to Vista, my NVidia drivers for my video card were awful. They didn't even support the native resolution of my widescreen LCD. The Sound Blaster drivers worked, but weren't anything to write home about. Now the drivers are much more robust. While the XP Sound Blaster drivers do have more functionality than the Vista drivers, nVidia has really gotten their act together and made some great drivers. Never had any trouble with my printer, though. I tend to blame the hardware manufacturers for bad drivers, though. It's not like they didn't know that Vista was coming for ~5 years.
I'm with you on the "software that does everything for you" angle. That's the exact reason I hated Windows 95 so much. But after some experimentation, I've found that Vista is much more customizable than most people give it credit for. Most, if not all, of the automated "helpfulness" can be turned off via the new, unnecessarily obfuscated Control Panel.
I'm certainly not a Microsoft Fanboi or anything, if you don't want to run Vista then don't, I don't care. If you have hardware below the *recommended* (not bare) minimums, then don't even think about it, you won't be at all happy with it.
And before anyone complains about Vista using up half your RAM just to boot, I should explain that this is a feature called precaching. Vista preloads around 40% of your system RAM with the most commonly used programs on your computer, so when you launch one of these apps, it starts a lot more quickly. XP does it too, just not nearly as aggressively.
I just enjoy sharing my positive Vista experience. It seems to me that most of the people who bash Vista have never run it - and I mean RUN it, really given it a chance, given yourself a chance to get used to it and learn how it works. That's what it took to get me to Win95, I had to *force* myself to use it for about 2 weeks.
Windows 3.x was a "shell," that ran overtop of DOS; not an operating system. Therefore, you still had DOS support, and you didn't have the "fragmentation grenade" experience like you did starting with Win32/Win9x.
DOS was nice - it took you about five minutes to shuffle things about when you needed to. You went to the directory for the programme, and all of its pieces were in there (vice Windoze.)
I have never run a new version of Windows "when it first came out" - Win95 I started with in 1997, Win98SE was in late 1999, Win2K was ~2002, and WinXP was about three months ago. Enough time for M$ to get all the kinks out, issue the first few service packs, and for me to get a useful number of reports from the field.
Will I run Vista? Maybe I'll be dragged into it, kicking and screaming. I'd like to see more software support happen for *nix tho - *nix doesn't break anywhere near as often as Windoze (neither did DOS, come to think on it...)
I keep hearing about how "extensively tested" the new M$O$ is, but I also keep seeing "Service Packs" and Gawd only knows how many "Hotfix Updates" for everything - so what were they testing? The interface by Fisher-Price?
I don't want flash, I don't want chrome, and I don't want a cartoonish interface. I don't need to be protected from the inner workings of my OS - tell me how it works, instead. I just want a system that bloody works - how I need it to, when I need it to, and without loading me down with extraneous crapola. Is that so much to ask?
The last M$ operating system I liked was MS-DOS 6.2. Everything else has been used "under protest" - simply because M$ stops supporting old versions of bloody everything shortly after the new version is released. That's why I've got archived operating systems - going back to about MS-DOS 5.0...
Not that I'm a Luddite - but the saying of "Newer isn't always better" definitely applies here.
