Lowrange2
- Abbeville, SC
Personally I'd stick with steel unless it was for a dedicated rock crawler.(which I don't own.)
Steel is simple, but it has it's downsides. One, when it fails, it is incredibly dangerous. Two, it's heavy. Three, as mentioned, frayed wires in the cable HURT. Heavy gloves solve that one though.
Synthetics have a lot of pros - safety in the event of a failure being at the top of the list. Where they fall down is in UV/weather resistance. While great strides have been made in durability, all synthetic materials, and most natural organics degrade over time due to sunlight and atmospheric exposure.
Install a synthetic line on a winch, roll it up, and leave it on the front of your daily driver for five years, using it 4 times. You'll notice color bleaching on the line and fraying. Time for a new line. A steel line would only need cleaned and lubricated in that time, unless damaged during actual use.
Both steel and synthetic have problems caused by improper winding on the drum. Synthetic is reportedly a lot pickier then steel in this regard, and I've read of people having to cut stuck synthetic off a winch. This is a misuse issue that proper winding solves.
Agree with this. I run Synthetic line on my trail rig and I run steel cable on my DD. I don't use the DD winch enough to justify the price but I use the trail rig winch almost everytime I go out.
The synthetic line is far from light duty. I've never broke either a cable line or a synthetic line.
If you use it a lot - go with synthetic. If you don't use it a lot - go with steel cable.
