You can set caster with the lower control arms,they are factory servicable.And yes the only to set camber is with an adjustable upper ball joint(not worth the time or money).
Caster is set by loosening the lower control arm bolts at the frame end, loosening the adjustment shoe bolts (at the back end of the mount), and installing/removing shims for adjustment.
mostly if your camber is out,it means your ball joints are shot and letting the top of the wheels kick in,or somthing is bent.lifting it wont affect camber
