DirtyMJ
- Prince George, BC
So, as I see it you have two options (and something inbetween) which would be welding it entirely on the vehicle, or tacking in place and welding it off the vehicle. If you're to weld it off the vehicle I'd think that you would have to design it accordingly in that you'd have to actually be able to take it off - ie, all mount locations would essentially have to be outboard of the body's major dimensions. But if you're to weld it in place care would have to be taken so that the nodes could also be accessed for welding. Which poses more of a problem if one means to keep the cage tight to the body.
Now, I'll go out on a limb and also say that most people would MIG weld their cages, with the exception of those who have the means and desire to TIG their cages.
Am I correct in these assumptions?
Anyways; I'm in need of an exo for my MJ and I'm still weighing my options on execution. I'm limited in space in that my garage only has a 8' ceiling, so if I'm to tack the cage in place and remove it for welding some major creativity would be needed. Hence I would like to weld it in place if at all possible. Which brings me to another limitation - I can't MIG weld. It will be sticked entirely. Which you can actually use to get access to tight places sometimes - but a lot of the time it seems to not help. Also, I do not want my exo to get in the way of my wheeling - ie, if it gets me hung up I'm going to be in a bad mood. Saving sheetmetal isn't really a huge deal at this point - it's really more my life and longevity of the body as a structure.
I appologize for the pics being ugly, and that this is for a MJ but I used my XJ as I have more pictures of it for some reason (WTH?).
My design idea is something like this:
Rear, sides: (old pic, yeah, I fixed that ass end)
The cage behind the cab will not be any wider than it is up into the area where the roof tapers in by the rain gutters. Which means it's not going to help the body much. I figure I'll go with the nice big full X as there's not as much that can be done for lateral stability up front. The bars extending back to the wheelwells might be unneeded - but I will use them as I think it'll look hokey otherwise and I'm going to throw a big 'pane tank there anyways. The sliders are also extended so I can try to squeeze my batteries into that space as a saddle - because that would be cool.
Thankfully my XJ's front end is pretty much the same - other than it sorta has a bumper.
I'm debating if the fender area should go inside the sheetmetal or not. It's not exactly a huge deal if the fenders get messed (wait, they already are) as they can be replaced or flattened if I get in the mood to do bodywork. If they go inside I'm unsure how much protection I will have for the lights at the front. But if I build it as drawn I might as well not have turn signals anyways. And yes, a windshield bar. Do I need it? I'm just thinking I'd better not break the glass if I do it...
Okay, imagine this is a MJ roof:
Obviously this isn't the best design. Another X or a single diagonal cross would be better. But I think it will cause major headaches with the bending and welding if I was to do that. Mostly this would be because the tubes along the sides and front are not above the roofline. Should it matter?
Thoughts, comments, concerns? I'm going to start figuring out how I can build this thing next.
