JoeyClements
- Houston, TX
I have a 96 XJ stock under the hood. I have the well known leaking transmission lines. I want to do 3 things at the same time so any ideas are welcome. I want to add a
trans cooler (live in Texas!), change to electric fan (push or pull?) and replace the leaking lines. So do I use a push or pull fan? Do I add the cooler in or out based on the fan? Do I use stock replacement lines or is there a better way to do it? I live in Houston and it gets HOT. I will not tow but will run low speed stuff once in a while. Some hwy miles to and from work in the rain and be able to take the Texas off ramp if needed!
Please comment or email as I welcome all ideas!
[email protected]
[email protected]
