Some of you guys are making a mountain out of a molehill.
Just unscrew them, if they snap off punch them out with a punch & BFH, fish in New Grade 8 Hardware (Use a piece of wire wrapped around the bolt to fish them in). It’s less than an Hours work! If you are lifting the jeep installing a pair of http://detoursusa.com/xjstm.php these will extend your existing shocks & end the XJ rear upper shock bolt dilemma forever!
And remember, if you apply enough heat to a nut or bolt to turn it cherry red, it’s now trash! Replace it with new (properly graded) hardware!
94 XJ 4.0 chry8.25 blah blah. Just did the shocks and leafs. Nothing broke. Front leaf bolts were a pain. but nothing broke. P.B.balster on all and heat on the leaf bolts but NOTHING BROKE!! I get snow but they don't salt they sand. P.B. for sure then heat.
Just an idea, since there isn't much room under there, I just bought an air hammer from Lowes for about 30 bucks and just knocked the weld nuts out. Much easier than swinging a BFH in thar small space and the air hammer will can be used for lots of other jobs on the XJ.
97 XJ originally from Ohio. I snapped the bolts off, drilled and tapped them for the next size up... I think from 5/16ths to 3/8ths. Put in stainless hardware for good measure. (The next owner should be pleasantly surprised.)
I just had to do this on all four rear upper bolts last week. You'll break them, then just bang them out and like mentioned before just tape the new nuts and washers on there. You just have to fish them through the little gaps. The worst part is the crap falling on you when you are banging (I used a punch I picked up from Lowes and a 9lb hammer I had laying around).atriot:
