I have new Bushwacker rear fender flairs for a Cherokee. 2 pieces for the left rear, only the rear of the 2 pieces for the right rear & all the hardware and rubber gasket for all pieces. Snap up any single piece if you want. Thom
I have my 2000 4.0L HO long block from my XJ w/ only 51,700 mi on it. Has plug for block heater. Ran perfect, never overheated while I had it 3 years, always used synthetic, have records. Never had a problem, just removed when I swapped in my stroker. Will bring to FF if someone buys before I leave 10/2, then goes on eBay. Make me a good offer. Thom
I have 4 Maxxis Creepy Crawler tires only, not the rims. 35 x 12.50 x 15 bias ply, tough as nails, no tairs or punctures. Hold air perfect. Now measure 33.5" side to side, weighted, aired down to 9 psi on 10" rims. Should be able to run them if you run 33s and can take 1/2" more, of course if you use narrower rims they'll be taller. ~$1300 online new, shipped. 9117 mi on them 90% hwy. Siped, work great. 5/8" on side lugs, 3/8" left on center lugs. If no one gets em by 9/15 I'll list them on the pirate site and not bring them to FF. Thom
I have the stock front drive shaft from my 00 XJ, it slides from 30 1/2" to 32 34" measured center of end U joint caps. Correct fit for my 6" lift and Dana 44. U joints are real fine, splines in center slip are slightly loose. so It moves up and down about a half inch, the splines don't look warn though. This shaft has 56,300 mi on it. Never had a vibration. If no guy buys it by 9/15 I'll list it elseware. Thom
I have Dana 44, 30 spline front shafts of stock alloy, 6500 mi on them, from my Rubicon Dana 44 front in my XJ. I swapped to CrMol shafts. 1st good offer gets em. Thom
I have 2, new in boxes, front Rancho RS9000 XL shocks, any model number you need. $100 for both, PM me for details. Sorry, I think it fair you pay me if you want me to save them for you. Thom
I may decide to sell my new (never installed) Brown Dog motor mounts and my nearly new limiting straps since they are now too long for what I need. :doh:
I have a Dana 44 diff protector cage by Purple Cranium. Front or rear. Includes all bolts. It's scratched but no cracks. Lets air get to diff cover so stays cooler. The aluminum cover with fins is not included but will sell later, if you're interested PM me. Cost $115 new, how about $45. Will bring to FF, or I'll ship, you pay, check cost from 59917, + $6 to box & take to your shipper.
