phil04
- Riverview, FL
99 XJ 4x4 Stock 200K on body
I'm trying to determine if this is a a/c compressor going bad or something else. When I'm on a long highway drive, after about 20-30 minutes, i will intermittently get a drag or pull from something which feels like i'm quickly tapping and then letting off on the brake. It will sometimes happen ever few minutes, and sometimes several times in a row, every few seconds. I turn off the a/c and it usually lets up but every so often I believe it happens again even with the a/c off. I would think if it was the a/c I would hear a belt squeal, but I do not hear anything.
Some other symptoms that may be related, or may not be:
I do have some vibes and some play in the steering
I get some squeaking when I turn
The motor feels a little down on power right now and idles a little rough
Any thoughts? Thanks so much!
