asp
- Westport, MA
an LSD has spider gears like an open carrier and a clutch system outside of the shaft gears, one for each shaft. i'm not 100% sure on how everything in there goes together and i'm sure it varies from design to design, but basically when the torque on the axle shaft exceeds what the clutch can hold, it breaks free and the spider gears take over. when offroading, this will happen as soon as one wheel gets stuck (the other will spin) or just plain loss of traction and it is effectively no different than an open differential. a locker doesn't care how much torque there is (up to failure) it will spin both shafts the same speed. once again, HTH
