Steering column swap
no patience
Antelope,CA
So I have done a search using the search option, but no luck. I have also googled it but no luck.
I have a 89 XJ with a standard non tilt wheel and I would like to put a tilt wheel in. Now shouldn't it be pretty much an easy swap from another xj?
From what I can remember all I have to do is make sure that the proper wiring is in place (blinkers,wipers,ignition) and it should be a straight swap. Please correct e if I am wrong.
t believe the wiring should be similiar. the only major difference would be if it has intermittent wipers, where adding thr delay module should make that work. also i would get the lower shaft that connects to the gear box in case thats different too
thanks, I when i pick one up I will pick up the steering shaft with it, just incase anything is different.And if it is the same at leas I will have a spare.
I do not know if the Renix era colums are different. I do know that the GM style column was used till 94 though. I think the internal wiring may be different.
Don't know about 94 and up , but any early GM style will work. Mine had no tilt/cc/tilt or int wipe. Has everything now. Just make sure use the one for your tranny (AT or STD).
I think that the new steering column have to came from a Xj with the same type of tranny. Manual and auto they have different item numbers in the parts catalogue.
Regards
