- NE Texas
and if you knew anything yourself, you would know not everything in life needs to come from a "Kit"Where are you getting your perches and accessories from? The kit for everything from M.O.R.E. is $200 alone. Then to pay a shop to weld them will be more than $100. Then you still have the flange to buy. Then, if you want the e-brake to work add even more money.
You should do more homework before you give bad info.
you can get perches for about $40 for the springs. and the shock brackets are about $40..
and you can make the E-brake work without any "purchases"
Spring perches $30
http://www.ruffstuffspecialties.com....html?osCsid=4500ba08f906e94323c12a103824c8e9
and hey look, i found a "Kit" that isnt $200
http://www.ruffstuffspecialties.com/catalog/simple-spline-p-186.html
and to top it off, i dont know about your area, but i can have all that welded on for $60 at my 4wd shop..
