Well, I have a flood of updating to do, it's been difficult due to lack of high speed internet at my new house, so I'm working off a cell phone..
I've done a handful of small fun projects, here's a bit of a picture dump
Added a trans temp gauge, air pressure gauge and oil pressure gauge
the factory oil pressure gauge does NOT read accurately even with a brand new sending unit
Upgraded to poly motor and trans mounts
Added a main breaker and secondary fuse block for accessories
And upgraded the interior lighting a bit
Found this nifty item called the Kolpin Saw press, It's meant to mount a chainsaw with or without bar sleeve, to an ATV.. Well, I figured if it can handle the rugged ride or a Quad, it should be solid in my jeep, Sure enough.. The saw is solid and doesn't rattle, Takes 5 seconds to remove or put back
With how dark it gets in the forest, it's hard for your eyes to transition from the intense light of LED lightbars while driving forward, and then trying to backup into a black hole of nothing.. The fix for me was a 20" single row light-bar
I picked up An EMPI dual lever cutting brake setup, this immediately went in the parts pile for axle swap,
And with that said..the holidays always make finances limited for a while, now that the dust has settled, I'm able to put some focus on the jeep again.. Tax time tends to ad a booster to that also.. The jeep will be going under the knife this week.. It's time to finally empty the parts shelf and really enjoy the rig again!
