Matt98XJ
- Sanford Stadium, row 5.
I very much dislike cops in WA.
jeephog said:For those who run doorless with power windows and locks and such, how did you handle the wiring? Trailer style plug? Just curious.
- Is there any way to hook up some wires to the harness where it disconnects and then a switch so that you can have them work? Cause I was thinking about putting a switch underneath the lip of the front pannel below the steering wheel to lock/unlock, and windows. Or is it one of those deals that if the whole harness isn't connected nothing works?jfiscus said:Power door locks & ALL windows will not work with the drivers door disconnected.
jfiscus said:I did however, have trouble the first time I made the quick-discos for the doors with getting the correct shims & alignment. I also found it to be easier to use a longer bottom pin than the top one.
so u can lock the back hatch duhxjohnnyc said:Just curious...why would you need the power door locks and windows to work when you have the front doors off??
But you can use the key to lock the back hatch.husky250rider said:so u can lock the back hatch duh
There are still 2 windows in the back doors that I'm not going to take off, and it would be better to have control over them.xjohnnyc said:Just curious...why would you need the power door locks and windows to work when you have the front doors off??
Yes, this is true, but if I have my car running, and my friend goes to open my hatch, I don't want to have to shut my car off just to open it up. Plus, I go out to my car numerous times when its in the driveway, and I don't want to get out there, realize I forgot the key, then go back and get it. Yes it sounds like I'm lazy, but it would just be so much easier.xjohnnyc said:But you can use the key to lock the back hatch.
jayuu said:not to hijack, but would it be wise to take off the hatch too for better air flow? maybe throw one of those truck racing nets across the bottom?
CamoXJeep said:Most states if not all require a driver side mirror...
begster said:jfiscus, thanks for the suggestion, sounds like a good idea, I was planing on driving up to a salvage yard tomorrow for a new fender and tail lights, I'll pick these up while im up there. I agree this sounds like it will work.
