proracedriver616
- co
My money is on the coolant, had a pinto once with bad coolant, it had almost all the same exact problems your jeep has!
If you solved it by covering the port, you where the issue is.
Some IAC's require adjustments prior to install (usually they will have a small card stating so). Swap the Latch Relay for another relay you know is good. Try starting again, twice.
If that has no effect start tracing the IAC wiring back.
Enjoy the pizza, and good luck.
also, tps numbers are 4.91 input V and 4.15 output V.
well, finally got the coolant sensor in.
no change.
tried the tps swap again.
i did learn if you get a new or used TPS and it wont give you the voltage range, slightly bend the arm and then try it.
so i checked all the wires for the knock sensor, temp sensor, and o2 sensor.some are scorched, but no cuts. i put new plastic loom on them and re routed along the stainless steel hard line and down past the back side of the engine mount. i am ruling out those wires and sensors as my problem.
the wires were routed around the end of the manifolds with no loom on them.
i have a CPS sensor to try. i ll try that sunday and report back.
running out of ideas here.
got to get rid of the high idle.
ok, found a thread Cruiser dropped in on and suggested more cleaning, did that.
i cleaned the wire terminations on the small relay by the battery. and pulled each black square relay and hit the blades with a wire brush and a shot of wd40 (it is all i have) where they mount.
the nut on the rear of the head, i cant get to it so i am going to just make a new ground cable in the morning. and mount it where i can access it if i need to.
anyone think the CPS can be left or what? i have a used spare, and no idea if bad or not. it was working in my MJ and swapped out and noticed no change in it so i kept the CPS as a spare.
yesOn the square connector transmission side with the harness connected to the TPS?
how to change idle voltage? mine never changesYou can always try swapping out the jeep LOL.
" wires for the knock sensor, temp sensor, and o2 sensor.some are scorched,"
Now you need to get serious about using a volt-ohm meter to run wire tests one wire at a time. Do you have the Renix Multiport Injection factory manual? It saved me years on BS. Did you know that the TPS location is adjustable to change the idle voltage?
on mine, no change no matter where you position it. damn jeep.
jeep is working and running good except this damn high idle. i had a lot of back firing o
ut the intake. can this blow out any of the gasket? i hear no leak except all the noise from the IAC hole. when i block it off with a rag, it brings idle down and i cant hear any hissing or vac noises. spray doesnt reveal any either.
and today i lose 1st and 2nd gear. lmao really
