- San Jose, CA
I don't care if they're the best ratchet straps on the planet. Its still a bad idea. And that should mean something coming from me :jester:
As for how I did it... remove both the wheels so you have more room to work with. Put the jeep on jackstands right behind the LCA mounts. Remove the tires and let the axle drop. Put the jack under one side of the axle, right next to the knuckle, and jack up the axle until the suspension is compressed as far as it will go and the entire jeep starts moving up too. Then go to the other side and the coil should be loose enough to move up and down... move it up as far as you can, pull the bottom out, and pull it down off the tower. I had to have a buddy stand on the knuckle on the side I was working on to help bring that end down enough to get the coil off. Then switch sides and repeat.
And again, this is with short arms and a 4.5" lift that sat closer to 5", no ratchet straps or coil compressors necessary.
Sounds easy enough, I should be able to replicate that with relative ease this weekend.
Thanks.
Hmmm, I like that idea. Never thought of that. That'd be simple.
What happens when the spacer finally comes out and the spring shoots to meet the top? Hope your finger or tool isn't in the way.
All I unbolted was the shocks. I left the trackbar, control arms, etc solidly attached. Jack the Jeep up, put it on jackstands. Put the jack under the axle. Break loose the lugnuts, unbolt the shocks at the axle end, jack the axle enough to remove the tires. Now move the jack to one side of the axle, and jack it up. You may have to put some pressure on the side you're working on - have a buddy stand on it like mcantar said. Pull the bottom of the coil out, remove the spacers, replace the coil. It'll go in easier now. Repeat on the other side.
Done it once using a ratchet strap on an RE 4.5" coil. Strap let go, spring shot through the roof of the work area. Never gonna do that again. We got lucky on that one.
Sweet, sounds easy enough. I've been stacking my jacks on my spare tire rim and boat trailer rim...was fine both times I did that for the rear leafs...this okay?
Damn, yeah I don't want to mess with that at all haha I gave up the ratchet idea fast.
