I understood that you had to pull the tranny. I had no idea you could do it by just removing the starter. SO if I read correctly you can only chang out the bottom portion of the seal??? Thanks for all your input it will really help, I guess I better get wrenching cause the oil leak is getting progressively worse. Someone told me about those seals on the oil filter deal, I think I might just change those out also cause I HATE when my Jeep leaks oil..lol
So anyways I will need to buy 2 seals, I do not need to pull the trans?? It will only take around 4 hours?? Any special tools/items I might consider buying before I get into it.
