Raised pitman arm?
Angus
OK this is going to sound strange, but is there a bolt on pitman arm that is higher than stock. I have a WJ front end conversion with all the linkage mounted below the knuckels. I want to make it a true high steer, but my drag link to trac bar angle will be off. If I found a higher/straight pitman arm that would solve the issue. I would normally just lower the trac rod frame bracket, but the current one is great. I also allready have the JKS trac bar raised bracket on the axle.
Thanks, Angus
Thanks, Angus
Angus, isn't a TJ pitman shorter in drop? IIRC, it is by an inch or better.
Are you running a straight or bent trackbar?
My trac bar is bent for oil pan clearance? It is a modified JKS bar. Of course the angles are measured from bolt to bolt iregardless of the path the bar itself takes.
I don't remember about the length of it, but you might want to look at an FSJ pitman arm, they are FLAT. A drop arn for an FSJ is about the same as an XJ or ZJ.
incorect
the FSJ pitman arm is too long for a d30 knuckle (or at least stock ones)...
