Angus
- Kansas City suburb
OK this is going to sound strange, but is there a bolt on pitman arm that is higher than stock. I have a WJ front end conversion with all the linkage mounted below the knuckels. I want to make it a true high steer, but my drag link to trac bar angle will be off. If I found a higher/straight pitman arm that would solve the issue. I would normally just lower the trac rod frame bracket, but the current one is great. I also allready have the JKS trac bar raised bracket on the axle.
Thanks, Angus
Thanks, Angus
