gixser
- Avondale AZ
Fits
1987-1995 Wrangler YJ
1984-1991 Cherokee XJ
1986-1991 Comanche MJ
Brand new in box. I opened the box only to read the instructions. I have a different type Dana 30 so I cant use this after all
http://www.4x4posi-lok.com/app_jeep.html
4x4 Posi-Lok replaces the vacuum actuator with a cable operated actuator that puts the driver in control of the engagement from inside the cab. After engaging the transfer case, a one inch pull of the 4x4 Posi-Lok cable connects the right front axle to the intermediate shaft using the shift collar and fork, and 4-wheel drive is engaged! Simply reverse the procedure to disengage 4-wheel drive. 4x4 Posi-Lok also works great with lockers! When the front axle is locked, you can disengage the passenger side in order to make turns without wheel hop
150 or trade for ?????
