I have an oil blow by problem that I can't rid. I have had the valve cover glass bead cleaned and I have replaced all of the vacuum lines on top of the motor. I can drive in the city just fine with no blow by. As soon as I get on the highway and have to climb some highway grades, raising the rpms for a length of time, when I let off the accelerator to turn off to the trail the motor pukes oil in my air box and I have a large smoke screen. One of my thoughs is that I beleive I don't have a good seal on the rear of the oil pan because when it pukes oil I have a smoke screen as well from oil dropping on the exhaust pipe just below the rear of the oil pan. I think the oil pan seal is my smoke screen problem, but I'm stumpped about the oil in the air box. I was thinking that the seal issue might be the reason why the motor pushes oil up through the air box??? I want to drive my XJ to further trails than local stuff, but when I have the blow by issue I loose about 1/2 to 3/4 of a quart of oil and I'm afriad to drive more that 40-50 miles out of town. Any thoughts?
