- Torrance, CA
89xjJe3per said:The noise would be from what and i only need the the gears have a axle.. lol ill give u the 410 for the 355 or something i only live an hour and 30 mins away so no big deal...
I'm not really sure to tell you the truth. I never took the time to pay attention to it becuase I had the Dana 44 sitting in the garage (if it blew up I could've always dropped it in unbuilt).
The axle is yours if you want it. If you find the whine and don't like it you can always just use my ring an pinion with your internals. However be advised that you will have to re setup the gearset to do that. Personally I would just toss it in; if your axle is in fact non c-clip I would give swapping the axle shafts between the two a try just to rule out wheel bearing (and then I'd keep the other set as spares).
Sequoia
